ok update the hot water taps wont turn off in the laundry and i went to have a shower befor the water ran out and got zapped hardcore it made me scream and it hurt my hand my washing machine keeps on chirping and foxtel now wont work
not to mention my ragdoll cat is missing she was put in the laundry to sleep as per everynight with my other ragdoll and she is gone there is no where she can get out
ok thats dangerous. I suggest you call out an electrician ASAP cause theres something not right somewhere
-D
  • Replies 14.2k
ok its not funny, but why are you on here posting about it and not out looking for said cats
i have looked all morning for hours she was in the laundry there is know way she could get out what so ever its like she has vanished
im just more needing to know how to turn off mt tap in the bathroom without electricuting myself again
should be a tap out the front of your house a Mains water tap turn that off and you'll get no more water to your house
i tried that hun but the water is the hot water so it must keep running till all the hot water is out of the tank
the landlord wont be here for a few hours either
my hand is hurting and it had to be my sore one as well
turn the power supply to the house off
then turn tap off
-D
soulns liek a problem that a friend of min had last week.. a water pipe burst inside the wall, and filled the wall cavity with water which came leaking out of the power points :P
+1 to calling a sparky, its not worth yours and your sons saftey to wait
I have a question,
A mate of mine has just moved down to Adelaide from Gold Coast, and he has a VS Statesman with a 355 stroker in it, does he have to take the car to ID check or can he just change the address to south australian rego? I know if you buy a car from interstate you have to stuff around with all that ID check bullshit, but because he has just moved states and not sold the car can he just change it over? He can get a QLD 'road worthy' too by the shop that built his engine
kellie
ring 13 13 66 straight away. thats a broken neutral (as brad and i both thought earlier)
describe it as you got a shock from a tap when trying to turn it off, and a customer service crew will be sent out.
do NOT ring an electrician yet, ring ETSA straight away
i think your right because he isn't swapping names on rego might just be change of address form
even so they wouldn't give a stato too much grief except for 20% tint or something maybe a big ass blower
I'd say the boys at the ID office would slap a sticker on the car - Its absolutly offtap sounds like an animal and tucking 20's.
Cheers for that one, I'll be sure to let him know.
I have consumed so much alcohol this weekend, I am in pain :P
Signed the paper work for our home and land package this arvo
ended up going for this http://www.sterlinghomes.com.au/home-desig...cquarieensuite/
house and land package at munno para west, along with a few extras like stainless appliences, built in robes etc etc
come to 232k
will do me the missus and the little lad for a few years, then rent it out and onto bigger and better :P
just gotta flog this unit off now!, word of advice, avoid northern property world, there useless pricks.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
