  • Replies 14.2k
5stud, 2-pot single-sided fronts, 1-pot rear's
fixed a leak at the caliper (thru the bloody thing, nuts that keep the caliper together wernt tight enough)
the dust guard seems to be making some noise, something....... unless it's the pads against the rotors
yeah, should be able to boof, i got a set of R31 rears on order from DBA as "blanks" as i need them drilled for 5 stud. costs a small amount more as they have to pull them off the run n that, but ya should be able to
Anyone able to help me out? Need someone to go to JIS, buy me some R33 Tie Rod Ends - $175, and meet me somewhere, ie vilis, and i shall pay you back. I need the suckers in my hand by Saturday morning. If you are able to help out, send my mobile an sms on 0411876139 with your name and number and i shall call you back.
Edit: If they aren't in my hands by Saturday Morning, i will most likely be unable to attend the track day...there is also $50 in it for who ever does collect them for me.
Thank you to Madaz and Ruby for sending me a sms about picking these up. I managed to speak to JIS today, and he said he was going to be there till about 6-7pm, so i managed to pick them up :( . Also had a little chat, looks like a few of our forum members are regulars there *looks at Andrew and Dave* :thumbsup:
Hrmmm seems i could be stuck with going non turbo 33 rotors...Can you buy rotors that haven't been drilled at all?
could just get Growley custom machining to redrill 5 stud to suit 4 stud i had him do that for me before i had a 5 stud conversion and no troubles
http://www.growly.com.au/
npz Abe good to hear your sorted
Yeah Dave and I practically live there. If I could have gotten to Vili's tomorrow night to give them to you I would have picked them up for you. I live less than 2km from JIS, so pop in to see Koji and Paul frequently :P
So many toys, so little money - there are always things there I want.
i have some rotors with matt atm getting redrilled from hq patteren to ford pattern for the race car he can cross drill or put a few different grooves for a pretty good price .
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
