  • Replies 14.2k
5stud, 2-pot single-sided fronts, 1-pot rear's
fixed a leak at the caliper (thru the bloody thing, nuts that keep the caliper together wernt tight enough)
the dust guard seems to be making some noise, something....... unless it's the pads against the rotors
yeah, should be able to boof, i got a set of R31 rears on order from DBA as "blanks" as i need them drilled for 5 stud. costs a small amount more as they have to pull them off the run n that, but ya should be able to
Anyone able to help me out? Need someone to go to JIS, buy me some R33 Tie Rod Ends - $175, and meet me somewhere, ie vilis, and i shall pay you back. I need the suckers in my hand by Saturday morning. If you are able to help out, send my mobile an sms on 0411876139 with your name and number and i shall call you back.
Edit: If they aren't in my hands by Saturday Morning, i will most likely be unable to attend the track day...there is also $50 in it for who ever does collect them for me.
Thank you to Madaz and Ruby for sending me a sms about picking these up. I managed to speak to JIS today, and he said he was going to be there till about 6-7pm, so i managed to pick them up :( . Also had a little chat, looks like a few of our forum members are regulars there *looks at Andrew and Dave* :thumbsup:
Hrmmm seems i could be stuck with going non turbo 33 rotors...Can you buy rotors that haven't been drilled at all?
could just get Growley custom machining to redrill 5 stud to suit 4 stud i had him do that for me before i had a 5 stud conversion and no troubles
http://www.growly.com.au/
npz Abe good to hear your sorted
Yeah Dave and I practically live there. If I could have gotten to Vili's tomorrow night to give them to you I would have picked them up for you. I live less than 2km from JIS, so pop in to see Koji and Paul frequently :P
So many toys, so little money - there are always things there I want.
i have some rotors with matt atm getting redrilled from hq patteren to ford pattern for the race car he can cross drill or put a few different grooves for a pretty good price .
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
