nah no shopping list
was thinking either tribal again or the swirls that the 31 has :)
and steve as if u forgot the bacon!!!!!!!!!!!!!!!!!!!!!!!!
that car paint sceme has been used a few times already,a guy in QLD on here has one on his GTT and Phatt Audio Customs in Vic has one similar turned into a JDM Cop Car.
JDM R34 cop car video
try some new graphics Cara, not the swirls or tribal ones , something fresh!! and PM or SMS me sometime homie...lol
  • Replies 14.2k
Just got a couple of quotes back for a standard rb26 bottom end swap.. 7-9k ouch.. :ninja:
Looking at a couple of built long motors in japan the moment.. One's a tomei 2.8, 270 tomei cams, tomei oil pump, N1 water pump etc. in a N1 block. Motor has just under 4000k's on it.. May aswell get it checked out by a shop over there and do it right the first time i spose..
Can't justify spending that kind of money on a standard bottom end..
sucks. :laugh:
rb30? :ninja:
I've considered this.. But weezy gets mad and reckons it's molesting it.. Might throw in a rb30et with a A6 bottom end just to make him rage.. haha
Fitspatrick had a rb26 awd adapter for $450 (don't know if they still do) then there's around $600 in machine work to relocate the oil pick up then drill and re tap the rb30 for bigger head studs and a tensioner..
Thats about as much as i've looked into it so far.
Dayum thats quite cheap...
Bargain if you can get it, tho I hate to think what the shipping fees are for something so heavy
-D
Yeah it's cheap at the moment and shipping is around the $1500 mark from what i saw. I'm keen if it goes for under 9k..
That would be around 11k all up including shipping and taxes.
If it goes for any more it might be a better option to get a nitto 2.7 built here..
Weezy has a point (as a purist lol) as Rb30 bottom ends are awesome for the power gain, but the car loses value when you take the original rb26 out of it, which is the only reason I'm going to stick with the 26 bottom end
-D
No pos RB30 bottom ends should be in a GT-R imo
:ninja:
Dont get me wrong, I'm all for twin cam RB30's in VLT's, GTSTs, etc but not a GT-R... C'mon lol
Think I should of called before I went for a drive, went all the way to MC Doyles Crash Repairs and they were closed... as in like they didnt pay their bills and got shut down. Guess I'll have to take my business elsewhere...
11k shipped for engine worth 5800?
Who's making a couple of grand?
My r34 rb26 motor was under 3k del
Yeah bit too much for shipping. I paid 60,000yen for a pallet (~A$700). If I had more money I would have loaded it up.
And Vu plz don't go to mc doyle unless u don't care about how your car comes out.
They're that bad are they? I've heard good and bad about them, was thinking I'd try them out myself but seeing they're close, ah wells.
What i was meaning to say was i'm prepared to pay 9k maximum for it and that would be around the 11k mark delivered after shipping and taxes.. If it goes for any more than that price i'd be looking into getting a motor built here.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
