  • Replies 14.2k
Easily. The RB30 block causes the head to be situated very high compared to the stock 26, pm cubes and ask him about how much clearance he actually has (he reckons its not a lot)... cant run a strut brace with a 26/30 unfortunately
-D
ah cheers!
i knew the 30 block was taller, only assumed a touch though.
30mm is a lot in an engine bay for clearance issues. Then think that everything like exhaust dumps etc need to be re-fabricated to suit the taller block height. It's all one big task
thats why if you go the kakimoto route you get to keep all your dumps and stuff
as with strut brace Cubes kept the over the top plenum and inlet pipe work if you go front facing plenum you can have a strut brace
thats Gold Carl
-D
Cubes had a R32 GTS-t didn't he? It harder to fit the RWD RB2x/30 because of the over the rocker cover intake manifold which reduces clearance even further. The GTR's have more clearance but there are still bonnet problems, also with the GTR's you can't drop the engine like with the RWD's because your dropping the drive shafts as well.
There's 38mm difference in the blocks.
how? heads still going to sit 30mm higher than standard?
yeah had a seniors moment there :laugh:
yeah cubes also tilted the engine too from memory and dropped it a little lower in the engine mounts cant be done as your reason on GTS4 , GTR
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
