  • Replies 14.2k
you wanna know something funny?
I was sitting on the porcelain at the time and the missus yelled out, "WAS THAT YOU"!!!!
bbbbbbbbbaaaaaaaahhhhhhhhhhaaaaaaaaaaaaaaaaaaaaa stomach is hurting better let the advertiser know it was you farting nothing to worry about
seriously, didnt feel it at windy point. i do think i know the cause (and ive said it elsewhere). jake and i were doing mad "initial d" style togue up windy point at the time, im sure the patrol did a weight transfer (and unlike another mate who said "no matty. if the patrol weight shifted it would of divided by 0 and the world would have exploded") so THAT is what it was :)
dave, feel free to stab me in the eye :(
So that was you pete, I was on the poo collector as well, could hear it coming like a sub bass train, then bang toilet shook more then normal, and more sub bass vibration, between mud explosions.
that was the quickest earthquake I have felt, used to live in san fran, LA those become a tad more interesting. living on the island between oakland and san francisco. MAN MADE one at that. our navy barracks are the star shaped buildings
oh
my
god
ive had the best motivation to finish my car. better than doing a 1:29 in a GTR that wasnt mine too >_<
i'll describe the car, its light, has excellent power to weight, fierce response, impressive grip level, and the typical RB stalling characteristics.
oh, and its purple and turns heads :cool:
"10 bucks if you can guess what it is"
"how about 10 bucks if you do a burnout"
I need some ideas for suspension/coilovers as my front castor rods need replacing (so I thought I might as well do the whole lot in one go). I have researched JIC FLT-FAS but from what I've heard, they're probably going to be too stiff for normal street driving and some hills work, especially with Adelaide's shocking road quality.
So what I wanted to know is what you guys use and what you'd recommend.
Also wouldn't mind knowing who/what workshops can install them for me.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
