  • Replies 14.2k
you wanna know something funny?
I was sitting on the porcelain at the time and the missus yelled out, "WAS THAT YOU"!!!!
bbbbbbbbbaaaaaaaahhhhhhhhhhaaaaaaaaaaaaaaaaaaaaa stomach is hurting better let the advertiser know it was you farting nothing to worry about
seriously, didnt feel it at windy point. i do think i know the cause (and ive said it elsewhere). jake and i were doing mad "initial d" style togue up windy point at the time, im sure the patrol did a weight transfer (and unlike another mate who said "no matty. if the patrol weight shifted it would of divided by 0 and the world would have exploded") so THAT is what it was :)
dave, feel free to stab me in the eye :(
So that was you pete, I was on the poo collector as well, could hear it coming like a sub bass train, then bang toilet shook more then normal, and more sub bass vibration, between mud explosions.
that was the quickest earthquake I have felt, used to live in san fran, LA those become a tad more interesting. living on the island between oakland and san francisco. MAN MADE one at that. our navy barracks are the star shaped buildings
oh
my
god
ive had the best motivation to finish my car. better than doing a 1:29 in a GTR that wasnt mine too >_<
i'll describe the car, its light, has excellent power to weight, fierce response, impressive grip level, and the typical RB stalling characteristics.
oh, and its purple and turns heads :cool:
"10 bucks if you can guess what it is"
"how about 10 bucks if you do a burnout"
I need some ideas for suspension/coilovers as my front castor rods need replacing (so I thought I might as well do the whole lot in one go). I have researched JIC FLT-FAS but from what I've heard, they're probably going to be too stiff for normal street driving and some hills work, especially with Adelaide's shocking road quality.
So what I wanted to know is what you guys use and what you'd recommend.
Also wouldn't mind knowing who/what workshops can install them for me.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
