  • Replies 14.2k
$202 was an offer to JPS_TRADING LTD on ebay
the obx stuff from racingpartsdepot on ebay.usa
thats the standard price, shipping was $90, lifetime warranty and the quality is exceptional
a TSA worker told me if you get a speeding fine for 10kph or over on your P's you get disqualified immediately. Pretty harsh penalty! There are a lot of un-signed streets, being 50kph, snap @ 60 and your license is gone...
They've come down hard with demerit point rule changes in the last 5 years. And of course the price of everything (fines/rego etc/license fees) has increased enough to start hurting the wallet - just went and paid a speeding fine @ the post office on my lunch break... $220 for 70 in a 60 zone... I was bloody astounded when i saw the price of the fine when i opened that letter. Up by $50 since my last speeding fine, for the exact same offence... f@rk!
sorry to bring this discussion back up, but the section ive highligted there is no excuse
who can tell me the rule they bought in (cos they were too lazy / tight fisted to spend money and to signpost everywhere)
50 UNLESS OTHERWISE SIGNPOSTED
so that excuse really doesnt wash these days
/2c
and yes, ive had one speeding ticket, 76 in a 60 zone, on the easter weekend about 4 years back. a split second of bad habits cost me over 300 bucks
used.
jps trading were selling 3sets, sent an offer on a z32 afm + the cheapest hks dump set.
was surprised it was accepted lol, considering id just spent a $900 on a big 13" wilwood racing brake upgrade
see: brake.doc
Back to my issue. Wayne seems to think maybe the two hoses on my car are hooked up the wrong way on the solenoid and that i should try swapping them. Nothings gonna go bang if i do this? Like if the hoses are the right way and I've swapped em over its not going to reverse the pressure into somewhere and make it pop?
Yeah I might quickly go see Shaun and see what he thinks about it. I don't care that I'm only running 10psi, I'm just more worried about that if the restrictor isn't there, then why isn't it hitting that 1bar. Even with a turbo back exhaust it shoud be a little higher so who knows.
got boost controller? without boost control you're restricted to whatever your wastegate actuator is rated at, which i think is 10psi...
-D
no boost controller. I got a blitz 1 sitting here that I was going to use on my old gtst. Should work on the 26 shouldn't it? Or will I need one for a 26?
as far as i know a boost controller works on all, provided its setup in the right manner - best to ask ur tuner to install it really
-D
/2c
I was also thinking this earlier...but didn't want to say it/couldnt be bothered logging in at work.
I have received 2 speeding fines in the last 12 months...both for a car i sold to my parents about 2 years ago. So i get them to fill in the Stat-Dec, and i get of scot-free :D
I have received 2 speeding fines in the last 12 months...both for a car i sold to my parents about 2 years ago. So i get them to fill in the Stat-Dec, and i get of scot-free :down:
surely they've re-registered it in that time? :D no excuse that its not in their name heh
-D
-D
Nope, still in my name, so as far as motor reg is concerned...its still my car, but my parents paid me for it.
well its been confirmed! I worry too much and all I needed was a EBC and I'll see 14psi. Wow. Hahaha
hehe yep, or one of those adjustable manual taps
ebc is much safer inspite of their non regency friendliness. good thing is tho, theyre real easy to remove
-D
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
