  • Replies 14.2k
pull it apart yourself taking plenty of photos along the way so its not too difficult to put back together. take the head to an engine place (i have used richardsons engine service, but ask around there are plenty of good places). get them to check it over and face it.... if its not warped/cracked slap it back on and do a skid. if it is munted depending on wether you are going to do the labor yourself suss out quotes on a 2nd hand motor vs new head
btw its a good chance to replace hoses when the head is off
might get a start on it tommorow man cheers.
Might see if i can find a guide on it or something
I am going to need a favour while i am away (if someone can help me out) - Im off to Whyalla on the 6th May (thursday) and returning on the 20th May (also a thursday)
Sometime in that time im expecting a package to be delivered with my external wastegate in it. I need the whole package taken by Garage 7 so Decs can grab the bits he needs from it, then the package returned home.
As for when it'll be showing up, its sometime within the next 6-10 days. I can get someone to contact you when it arrives
Anyone able to help? There will be alcohol payment when i return......
I'll help you out Matt, send send the details of where i will have to take stuff, and what time frame it needs to be done.
hey matt i can help you out if you want
Porno exhaust, bit small tho :)
porn
ive got my exhaust bits here now.
currently has 5Zigen cat-back 1 muffler only
* OBX tuned length twin manifold, life warranty, $250
* HKS split dump pipes, used but excellent condition, $200
* OBX 2.5" dual into 3.5" front pipe, life warranty, $130
not bad with price hey, awesome quality to be brutally honest.
and if I buy the farm in Renmark I'll get a car hoist and spend some quality time making this track car
once we sell in say 15yrs time I could afford a R35 GT-R and sell the stagea & r32 rb26dett funcar
seriously considering it.......
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
