  • Replies 14.2k
sigh.
4 prank calls over about 5 minutes under the pretense of buying the 200.
im all for prank calls, but put some imagination into it, and make sure your mates arent giggling like school girls in the back ground, kills the joke before it even starts.
and surely people must have something better to do on a saturday night than trawl classifieds looking for pranking victims?
nope i dont think so but there is a trick to getting it activated to which Martin showed a customer in which i was there :ermm::P:banana:
not 100% sure if Gavins is the 2010 model that's the only unknown but LC2 is no where near as harsh as original LC
I am pretty sure they killed LC altogether in the US models when series 2 came out .... but yes the Aussie ones shill get a dumbed down 3,000rpm version which is much gentler and doesn't blow the trans.
excited. boat finally brought my container.
tomorrow get to p/up stich mags ($30 pound!)
grex camshafts, spats strut bar, 6-point roll cage
exhaust temp sensor, turbo timer, bride left hand seat rail
bride drivers chair, apexi power intake piping kit
got all the parts for the rb26 buildup in the cupboard now:
hks oil pump, hks step 2 cam springs, n1 water pump, acl race bearings
hks 87mm pistons, attkd rods, arp bolts, arp main head studs
cometic street pro full gasket kit incl 87mm mls head gasket
tomei sump baffle pickup kit, tomei oil gallery orifice, ati harmonic balancer
greddy timing belt, new idler/tensioner, adjustable intake/exhaust cam pulleys
30-row engine oil cooler, oil filter relocation kit, turbo oil cooler
hks split dump pipes, obx tuned-length manifolds, obx front pipe system, decat flex pipe
fitted wilwood superlite forged 4-piston calipers with 324mm drilled rotors up front.
got to install the external fuel pump and fuel surge tank system, then attack the exhaust
and sort out the seats, weld in roll cage and add to it, fill the belt/seat mounts in (eventually rego for 2seater?)
hey blokes looking for an answer to a basic q but just dont want to spend all night looking for it if possiable
mate has a 300zx 31 model vg30 he needs a set of injectors and was told only nismo items will fit due to the fuel rails ok thats fine but what size do nismo items come in? and are all nismo items interchangeable within all nissan stuff ie skyline,silvia,180?
whats the price(reasonable price) on a new set?
price on a 2nd hand set?
thanks guys
Edited by JETURBO
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
