  • Replies 14.2k
i got the 31 coz it was basically free.....
and id buy your s13 Kye, but i like CA's about as much as i like hepatitis.
i only want RB, nothing else.
I had the same mind back in the day
but after owning one, I rather like them. Sound much better then an SR and done 4 track days and hasn't missed a beat :) plus, it's regod!
f**k it, I'm doing another track day!
yeah and more $$$
f**k it, ill keep sliding the 31, dont care what others say.
eventually it will more than likely come to an end, THEN ill worry about another set up.
Kye, organise a private day!
i cant say iv ever driven a CA, its just the thought of a 4 cyl makes me feel all dirty
I look forward to taking you for a drive to change your mind, Scaring the shit out of you in the process. :P
Edited by D_Stirls
tell them tangles (big brendan- stagea) wants his safc&sitc back that got stolen by troy. :ninja:
I think you need to clarify which troy...its not me..lol
on another note, has anyone here heard how good or used the new BFG tires are ??? thread pattern looks cool and you can get semi slicks and slicks as well ?
and a wallpaper from there site.R34..lol
Not sure if non-FBers can see this or not, but check this out. Loved it.
http://www.facebook.com/home.php#!/vid...v=1218044052737
heh saw that, it was in the youtube thread a few weeks ago, along with the follow interview
good on him
-D
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
