  • Replies 14.2k
Cst's Wayne. I can hook u up a set when I'm bak in adelaide. Currently in a club in Sydney :mad:
We'll talk when your back in Adelaide man :P
Go hard! lol
Edited by Weezy
also have the thought that it was done when engine was cold so pistons and stuff still needed to expand etc..
specs:
Fully balanced
Arp main studs
Arp head studs
Acl bearings
Acl 1.2mm head gasket
Ross/acl pistons
Argo rods
Adj cam gears
Gates timing belt
Has a rb20 exhaust cam on the intake to take the vct off
Was built with all new Nissan bolts, gaskets, seals
Once you have different cams and or adjustable gears, comparing compression results to factory will tell you nothing. This is also the same if you fit a different H/Gasket and the pistons will probably be slightly different compression to the factory ones as well. The difference between the cylinders is what you have to look at but a leak down test is what you really need.
You wouldn't want the difference between cylinders to be more than 10 psi but that's probably not to bad for a cold test.
Edited by D_Stirls
yeh i was reading and found the results not to be too bad..
going to go look at the motor and possibly purchase it.. fit my cams, plenum, turbo etc...
and dale i love my eboost...
would never let it go!
Funny:
Bloody lucky:
:blink:
Brass balls for the bloke. I was at eagle on the hill one day back in 2009 and there was a bunch of hecktik biker boys in full leather on their GSXR's etc racing up and down, in 45 degree heat :\ Crazy kents!
I found out what that grinding noise was, in my drivers side wheel arch. The retaining pin for the hand brake shoe had popped off, and got stuck in the drum, where it started to get ground down. Now to source a pin, and spring.
EDIT: about $5 for a pin and spring from Grand Nissan, so I have ordered 4, may as well replace them all while I am at it, should be here tomorrow or the day after from Melbourne.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
