  • Replies 14.2k
yeh his mate bought a 31 and put mikes old engine (fully built rb20det) in it running a 3540 making 320rwkw..
there just starting a rb30 r31 with a to4z!
and they also turbo'd a cherade until it pushed a rod through the block haha!
Dude you should see the thing! It runs NOS until the turbo FINALLY spools up at like 20psi
All the big single turbo drag cars get on the gas while sitting on the t/brake to get the massive turbines to start making boost, its mad listening to it, especially when it hits the 2step + nos + t/brake is very very cool lol bangbangbangbang *slicks rip* lol. best sound ever is hearing some massive slicks rip as they grab traction
is it easier to remove and engine with or without the gearbox attached?
need to put a oil drain in the rear of the head.. and cant do it with the engine in..
anyone wanna help?
When i had my turbo installed, the mechanic put the oil feed line to the back of the head/block somewhere. He had to move the gearbox back a bit, and then tilted the engine, not too sure how he did it, but that's what he told me.
If anyone needs, Ive got a account set up on Yahoo Auctions Japan for buying parts. If you have have found something on there that needs bidding let me know.
Luke :)
Ooo ... that could be dangerous! :yes:
Hide my credit cards :cheers:
i knnow fitting restictors and doing internal mods but shaun said not to worry unless your rebuilding..
i have mines cam baffles and 26 covers which will help..
all built engines i have read in the FI have had this mod done!
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
