  • Replies 14.2k
Well, work just lost our major gov tender. We expected to get it too.
Spewing... I hate it when that happens, means the entire business starts cutting back in all sorts of ways ;\
Wanted to note here that I just got my car back from Boostworx (Road and track are booked out working on muscle cars this week) who were very good to look at my car at extreme short notice - z32's are now fitted and a partial tune was made by Shaun to get the car nicely drivable on the street. Have some niggling little issues that need to get addressed before getting the upper end tuned, however I was very happy with the price and service from Boostworx, so two thumbs up from me.
-D
Should look a bit like this and have the extra hole that is plugged up. I have a filter relocation kit and have a different setup that doesn't use one of these.
That is exactly what i have hooked up to the block Chad....will check for that extra hole on the side when i get a chance to mate....cheers for that :P
yeah Catch ftw our church has a laptop off them very good indeed
i dare say the one above would play a lot of modern games
although im not actually sure how powerful the gfx card is seeing im an ATi fan :P
NVidia GeForce GT320M 1GB
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
