  • Replies 14.2k
Back onto car repairs, I give a big +1 to
1. Allan @ All Type painted the front GTR style bar on my R34 and was MINT. Also did a repsray on the boot of my parent's Commie and was schmick.
2. Joe @ Profinish just respayed the front lip on the wife's Euro and cut and polished - came up a treat and price was excellent.
car audio stuff of all varieties
1. John @ Marvey Tech all round audio/ICE God, and nice buy to boot. VERY good prices.
couldnt agree more with all of this andrew. Joe and John are very good prices. im getting the body work done and the car resprayed in a different colour for less than some places quoted to do just the bodywork :blink:
speaking of CAMS, Ruby, is my membership card on its way???
:) You should have it by now.
Let me go thru the paperwork again and see where its at. Chances are I might have to reissue you another ... the odd one goes missing. Thanks Aust Post. :P
EDIT: PM sent Craig :blink:
anyone know if i can use r32 brake pads in r33?
Rears definately can, and Im 99% the front you can too.
i would of thought even if they fit they wont be utilising the surface area of the R33's larger front Rotor, as Dion said rears are fine
this sounds like news i should hear more about since i need a full respray, need to acquire more parts though
I'm hangin for this years,
Not that I know what I'm spending it on? May put it away for an overseas holiday :).
spend it on the pending slider :P
Speaking of which, you posted on my FB that you have 3 RB25's...care to sell me a Head off one? :blink:
nope sorry
one is only mine till paid in full which should be this week
one is in my car and other will get rebuilt unless i was to source a 26 head to which i cant afford so im stuck with what i have :blink:, soon to be 2x RB25
nope sorry
one is in my car and other will get rebuilt unless i was to source a 26 head to which i cant afford so im stuck with what i have :blink: , soon to be 2x RB25
...What if I can source a RB26 Head, and swap it for 1 of your RB25 Heads?...or how easy is it for a RB26 Head to go on a RB25 Block?
EDIT: Thought I could source a RB26 head, but I can't unless I do a bit more searching, but how easy/hard is it to bolt a RB26 Head on?
Anyone else hear about rego going up again in July by $35?
Lol, I'll be paying nearly $200 for 900cc 3cyl for 3 months.
FARK! THATS JUST GETTING INSANE!!!!!!!
we have to be the worst of in aust right?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
