  • Replies 14.2k
Back onto car repairs, I give a big +1 to
1. Allan @ All Type painted the front GTR style bar on my R34 and was MINT. Also did a repsray on the boot of my parent's Commie and was schmick.
2. Joe @ Profinish just respayed the front lip on the wife's Euro and cut and polished - came up a treat and price was excellent.
car audio stuff of all varieties
1. John @ Marvey Tech all round audio/ICE God, and nice buy to boot. VERY good prices.
couldnt agree more with all of this andrew. Joe and John are very good prices. im getting the body work done and the car resprayed in a different colour for less than some places quoted to do just the bodywork :blink:
speaking of CAMS, Ruby, is my membership card on its way???
:) You should have it by now.
Let me go thru the paperwork again and see where its at. Chances are I might have to reissue you another ... the odd one goes missing. Thanks Aust Post. :P
EDIT: PM sent Craig :blink:
anyone know if i can use r32 brake pads in r33?
Rears definately can, and Im 99% the front you can too.
i would of thought even if they fit they wont be utilising the surface area of the R33's larger front Rotor, as Dion said rears are fine
this sounds like news i should hear more about since i need a full respray, need to acquire more parts though
I'm hangin for this years,
Not that I know what I'm spending it on? May put it away for an overseas holiday :).
spend it on the pending slider :P
Speaking of which, you posted on my FB that you have 3 RB25's...care to sell me a Head off one? :blink:
nope sorry
one is only mine till paid in full which should be this week
one is in my car and other will get rebuilt unless i was to source a 26 head to which i cant afford so im stuck with what i have :blink:, soon to be 2x RB25
nope sorry
one is in my car and other will get rebuilt unless i was to source a 26 head to which i cant afford so im stuck with what i have :blink: , soon to be 2x RB25
...What if I can source a RB26 Head, and swap it for 1 of your RB25 Heads?...or how easy is it for a RB26 Head to go on a RB25 Block?
EDIT: Thought I could source a RB26 head, but I can't unless I do a bit more searching, but how easy/hard is it to bolt a RB26 Head on?
Anyone else hear about rego going up again in July by $35?
Lol, I'll be paying nearly $200 for 900cc 3cyl for 3 months.
FARK! THATS JUST GETTING INSANE!!!!!!!
we have to be the worst of in aust right?
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
