  • Replies 14.2k
Not that I know what I'm spending it on? May put it away for an overseas holiday ;).
im thinking about doing the latter.
might spend it on finally getting a retune on e85 for the 200 though.
FARK! THATS JUST GETTING INSANE!!!!!!!
we have to be the worst of in aust right?
pretty well.
Can be bothered quoting all the posts for the replies.
All the simota 4 piston calipers use the same pads, thats skyline, Z32 and S-series. The R33 have a larger diameter but not larger area.
There is no point in putting a RB26 head on an RB25 block, the ports are the same size, the combustion chamber has the same volume; the only advantage is the 26 has solid lifters but when you consider that a complete 26 head is between $1500 - $2000 you could probably turn a 25 head into a solid head for less.
And the 25 head has a has VTC.
Edited by D_Stirls
Abe i could get vct working with a controller but it doesn't interest me gtr's dont use it dont think you loose that much with out it, my seat of the pants dyno didn't feel that much lose in response
Ok, Well depending which cams I drop in, I may not be able to use VCT anyway...if anyone knows someone who is selling a RB25DET Head, let me know, K Thanks....Now off to work.
Wow! Copping some abuse from an Ebay keyboard warrior :)
I bid and won a crank and rods for my RS250 racebike so I could start the rebuild. I organise to bid on a piston kit he has and he agrees to wait until bidding on the next item has finished so I can take them both as the one package. Before the auction ends (3 days after winning the crank) I get an abusive email from him, saying pay now because he has other people offering mroe money for it. I promptly inform him that I am the winning bidder and we had an agreement on a combined payment for other items still at auction. He ignores me and sells the items to another buyer. Money hungry wanker. He only got 1/4 of what the crank could have gone for, but he must honour the auction.
I've reported him to ebay and given negative feedback. Now he's sending abusive emails like this ...
Dear **************,
your a f**kn puff the crank sold for less ,you are a week little boy hid,n behind your computer , do the world a favour and f**k off
- 6321kris 320523152698.jpgEnd time:06-May-10 19:09:29 AESTSeller:
Listing Status:This message was sent while the listing was closed.
I've copied the email to Ebay. See what they do with the guy now. My response to him was that if he was going to send abusive emails, he should at least learn grammar and some spelling first. :)
:blink:
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
