  • Replies 14.2k
Not that I know what I'm spending it on? May put it away for an overseas holiday ;).
im thinking about doing the latter.
might spend it on finally getting a retune on e85 for the 200 though.
FARK! THATS JUST GETTING INSANE!!!!!!!
we have to be the worst of in aust right?
pretty well.
Can be bothered quoting all the posts for the replies.
All the simota 4 piston calipers use the same pads, thats skyline, Z32 and S-series. The R33 have a larger diameter but not larger area.
There is no point in putting a RB26 head on an RB25 block, the ports are the same size, the combustion chamber has the same volume; the only advantage is the 26 has solid lifters but when you consider that a complete 26 head is between $1500 - $2000 you could probably turn a 25 head into a solid head for less.
And the 25 head has a has VTC.
Edited by D_Stirls
Abe i could get vct working with a controller but it doesn't interest me gtr's dont use it dont think you loose that much with out it, my seat of the pants dyno didn't feel that much lose in response
Ok, Well depending which cams I drop in, I may not be able to use VCT anyway...if anyone knows someone who is selling a RB25DET Head, let me know, K Thanks....Now off to work.
Wow! Copping some abuse from an Ebay keyboard warrior :)
I bid and won a crank and rods for my RS250 racebike so I could start the rebuild. I organise to bid on a piston kit he has and he agrees to wait until bidding on the next item has finished so I can take them both as the one package. Before the auction ends (3 days after winning the crank) I get an abusive email from him, saying pay now because he has other people offering mroe money for it. I promptly inform him that I am the winning bidder and we had an agreement on a combined payment for other items still at auction. He ignores me and sells the items to another buyer. Money hungry wanker. He only got 1/4 of what the crank could have gone for, but he must honour the auction.
I've reported him to ebay and given negative feedback. Now he's sending abusive emails like this ...
Dear **************,
your a f**kn puff the crank sold for less ,you are a week little boy hid,n behind your computer , do the world a favour and f**k off
- 6321kris 320523152698.jpgEnd time:06-May-10 19:09:29 AESTSeller:
Listing Status:This message was sent while the listing was closed.
I've copied the email to Ebay. See what they do with the guy now. My response to him was that if he was going to send abusive emails, he should at least learn grammar and some spelling first. :)
:blink:
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
