  • Replies 14.2k
I've been searching around the forums and keep seeing mention of fuel pump relays in R33's, but can't find anything with the location of where it is, nor does the boot/cabin/engine fuse boxes seem to hold a relay for the fuel pump, can anyone point me to where it is?
Ended up stuck on the side of the road for 2 hours while fuel pump fuses kept cooking themselves last night and wanting to look over as much of it as i can before going out again.
Cheers.
Cheers.
d'oh Right next to the fuel pump, ofc... just not labelled on the lid.
I think Madaz will like this
http://www.j-specimports.com.au/featured/1...sion-15069.html
Price seems way too low though - I thought even with the km it would still be a collectors item.
does seem low but its only 3.5 so that's a scratch and dent grade
i was sure most of them came with privacy glass too so not sure about that might of been an option
even so with only a build run of 400 would of though more than that
and correct if i had means of getting 21k i would be hot on it
:) i so want this car!!!!
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
