  • Replies 14.2k
a set of them would be half handy to make a smooth transition onto my trailer ramps. wonder if theres a second set at JIS :D
if im able to get my hands on this car that kristian linked me to last nite, i might need them :bunny: she looks fair slammed
lol you crack me up lol i had 5mm but i think they are/were lost in moving wayyyyy to many times cause i havent seen them in ages and didnt use them cause they werent big enough lol so joe from WW put some 30mm bolt ons lol tough as
anyone got slip on spacers i can borrow?
need them TODAY
I have 4 x 5mm sitting here in my shed Nigel. You can come pick them up whenever you like I will be home for most of the arvo.
They are for sale too if you want them Damo - $20 for all 4.
ill take them andrew?!
Where can I get some 5/8" braided hose lines and fittings from?
dont get braided get push on fittings with hose..
that way u can see the hose inside when it gets old and worn and they dont leak!
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
    • I love saying Samsonas lol. Maybe it's because I secretly want one, but also don't want to sell a kidney.
    • My budget has already blown way out but I've got most of the big-ticket items out of the way haha I just got the box back from the shop, got them to inspect it and install one of those refresh kits with all new syncros and bearings so should feel much nicer. But yeah if there's a weak point it'll be the gearbox, I'm gonna roll with it for now and hope it holds together. Do have an Xtreme organic sprung twinplate clutch to go in so if/when the box lets go I'll be back open for suggestions haha
    • Dose salivating at the prospect of being able to recommend a gearbox upgrade!
