  • Replies 14.2k
SH!t, just watch a mate i use to play footy with get layed out by sandilands.....
Kyle Sandilands? Kyle couldn't punch his way out a wet paper bag, let alone lay someone out. ;)
No, not that poof, Aaron sandilands, the Fremantle ruckman
Footy player? They're fairies aren't they? You just touch them and they hit the ground holding a limb and crying!
Hey Steve i hear that you have that engine running. Good to hear that it was all good.
Do you have the Engine Lifting Strap? (The one made out of seat belt material). I tried to find it the other day but i think i may have lent it to you?
Edited by D_Stirls
if they were 8s and 9s, perfect offset for a 31 streeter actually
but they're not, so agreed ;)
hence why i said the widths where shit...
8s-9s with more dish would be win..but then the price would be higher id say :P
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
