  • Replies 14.2k
Does seem to be a very nice car (for the right price) Adrian, thanks.
I've got John Munro twisting my arm at the moment to buy something a bit different though.......decisions.
sounds interesting, German or Japanese?
f**k me. what a weekend.
30 hours at work, 6 hours on the turps, 4 hours at strung out tonight, and what little was left either getting to and from work, or sleeping.
now to get a couple hours sleep, and head back to work for a nice cruisey 10 hour shift.
im rooted. been f**kin awesome though, front row just left on centre at strung out, i was close enough to rip with jason when he knelt down on the stage.
was f**kin awesome to have a catchup with the guys after the show, been 2 years since we were smashing beers and talking shop.
theres always a negative though, got smashed in the side of the head near the end of their set because some chick wanted to steal the set list id just grabbed, so ive got a massive f**kin headache now.
i honestly hope that chick is involved in a serious car accident tonight.
Edited by scandyflick
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
