  • Replies 14.2k
What's the issue? Tune related?
Could be a number of things. It's not there to make epic power. I just wanted him to throw it on and make sure everything was okay. But if its losing that much power something has to be wrong.
Just made a phenomenal 160kw@ 9-10psi!
Obviously Shaun @ BoostWorx is fixing it.
out of a 26 that is definitely low power.....i know your not after epic numbers but still should be higher then that......pretty sure Shaun will nut it all out and let you know what is going wrong with it.....hopefully nothing major mate.....
A stock RB25 (flywheel 187kw) only makes around 140rwkw. A stock S15 (147kw) makes 114rwkw. My stock V35 (206kw) makes 146rwkw. 160rwkw for a stock, tired nearly 20 years old GTR sounds reasonable.
my RB20. 172kw > engine feeling sick > 110kw
Hope you get it sorted mate, but the extra 2psi its missing for whatever reason would counteract some of the difference...
Thats exactly what I thought.
No boost restrictor, front pipes, catback and pods should of surely opened up the breathing a whole lot more.
My last car had most of the things youve listed there, and it would run a whopping 4psi on "stock" boost. I needed a boost tee to actually get it up to the standard 7psi. Funny thing is, they had a boost cut at 12psi with a buzzer that went off in the cabin when it hit... I could get my guage to read around 11-11.5psi when it hit. It wasnt leaking boost, it simply just didnt run would it should have without help.
I dont know if wastegate actuators get dodgey over time or not, but this car was in the same age bracket.
I just had a thought, if the BPV(s) was leaking and recirculating back into the intake, could that cause it?
Maybe, but would it be enough to only take off 2psi? On the standard boost gauge I get to the line under +7. +7 apparently being 1 bar or 14.7psi. So I assumed I'd be around 10-11psi.
But when Shaun said it should be making atleast 190kw @10-11psi and 230-250 on 14psi.
He said it could be a timing issue or exhaust issue. But it could be a combination seeing as I've just got a compliance cat (bashed) and some thrashed out trust front pipes and dirty dirty dirty apexi pods. That surely isn't helping me at all.
Its suprising how much difference little things can make. I gained noticably more punch just by removing the resonator from my 3" stainless exhaust. - unfortunately I cant vouch for how much it was in KW, but you get the idea.
Ask RBWARE how much difference an exhaust can make to your power output!
Also, I dont think the boost stock guage works very well somehow :rolleyes:
Its 14psi man, and if it weren't my engine would lean out and go BANG! as I only have standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
