When I replaced my iPaq PDA, I wanted an iPhone ... but the price just wasn't right at the time. Two of the guys in the office have them, and they complain all the time about something wrong with them. I figured I'd just get a 'normal' (read: boring) phone for now ... altho my Nokia does have touch screen for easy use and internet access (3G) albeit slow. :P
Ive had mine for 15 months and it hasnt missed a beat... ever!
Gotta love mass hysteria :angry:
  • Replies 14.2k
Its 14psi man, and if it weren't my engine would lean out and go BANG! as I only have standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
14psi is the end of the Boost Gauge, just because the needle stopped doesn't mean the boost does too haha. You were probably running 15-16psi + the cam gears that got you to 270
I'm. Running. 14. psi. dammit. lol
It was tuned and the boost was monitered and didn't move from 14psi right through to 7,500rpm lol
But yes, no doubt the adj cam gears did help but they're nothing 'too' fantastic but can make a massive help when tuning.
Have you heard from shaun? Does you car have adjustable cam gears?
I cant access all features of OS4 because I only have the 3G (as opposed to 3GS) but it still looks pretty, and works better.
I was told that the redsnow jailbreak will allow 3G owners more features. I won't update to OS4 just yet however
Can someone help me out with a paypal payment? Its only $50, but its for a part I need in the post asap. Will get the $50 to you asap.
Long story, but I've close my bank account that I use to have my paypal linked with. Now I have no paypal set up properly.
PM me if you can help ... thanks :angry:
Thanks for the offers guys. I've been sorted out now. Thanks Abe :P
I got a 3GS a couple weeks back for free so I thought I'd give it a go and I'm very impressed considering I didn't think that much of the original version the Mrs had when they first came out. Obviously jailbreaking makes them so much more worth their price imo
No cam gears at all and no idea why I'm running only 9psi with no boost restrictor. Man I'm so devo, I'm sure my old R32 would of had more power.
:cool:
heslo = epic post whore in the last couple of pages lol
heslo = epic post whore (fullstop) Nuff said :P
Haha beat me to it Andrew ;)
You are a little floozy whore Lukey Boi........what party tricks can you perform :P
You should've come to Kadina mate :cool:
:/ Cheers guys, feel special I do!
I would have Pete, but had other things on. Next time I promise
What Dohmar is saying Wayne is that no Skyline EVER has run 280rwkw with standard turbos and injectors. Go check the RB26 power threads if you don't believe me.
The ninja GT-R lol
f**k knows with these imports hey!
:cool:
Performance cars are cvnts.
Compression/leak down test is next!
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
