well, went yesterday and bought a set of those astro products ramps that everyone was bragging about
got to try them out today, i can now say i offer a "super low" towing service
(pics coming soon, phone is in car and im inside haha)
  • Replies 14.2k
everyone!??!?!?!?!1 I need 2x10mm spacers, if you have 4, then sweet, if you have 2x 20mm spacers, and 2x10mm spacers, HIT ME UP!
NEED ASAP! NEED BEFORE THIS WEEKEND, HAVE $$$$$$$$$$$$$$$$ WAITING :blush:.
Help a brother out
hahahaha nice one Matty i see that patrol is on ramps too
yeah, used my servicing ramps to straight line it, and the astro products ones at the end
thinking of buying another set, so i can join them together side by side (as they're perfect width for my ramps)
I have a ute if that helps...
Whats it rated to carry (what can your rear springs handle)? I got about 4 pallets worth of red bricks to pick up from a property in Aldgate. Numerous trips involved I know, but the bigger each load the better (less trips).
:blush:
Does anyone here have/had a boxer (dog) as a pet before?
A mate of mine a puppy and it was a bit of a handfull but im more concerned about later on in it's life.
Want a gaurd dog kinda thing that's not a rotti, shepard, dodderman etc to stay with my missus while I'm working away.
Boxers are one of the only dogs that don't EVER seem to grow up ..... I have met 8 year old ones at people's houses and asked how old they are cos they are still like a spastic puupy - only to find out they are spastic 8 (56) year olds.
Looking to buy an SLR camera, whats a good entry level one? I dont know much about them.
I have the Nikon D40, about a year ish old now, great entry level, awesome pics on auto, and not 5 billion adjustments like a 3000+ dollar DSLR. Feels good in the hands too.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
