  • Replies 14.2k
was a slow day in the office today...
we found a vhs tape and put it to good use
That was only stage 1. I was too busy helping with stage 2 and 3 to be bothered taking pictures
-D
Hard at work there Dohmar?
LOL, I work in a department store - mostly when its closed, we sometimes get up to a bit of mischief :blush: :blush:
ive got $100 for the whole day -__________________________________________________________________________-
once i get petrol and pay cams fee i wont be able to afford tyre changes
unless someone wants to buy some 33 parts ?
rear 5 stud hubs and knuckles ??
r33 console??
abs brake master??
Man, you've already paid $160 to enter man. What a waste of cash if you don't just borrow a little bit extra! FFFS
i didnt borrow that , apparently its part of my birthday present o.O
after my dad saw my tyres are on canvas hence not driving the thing , he went ape shit at me lol so HOPEFULLY they wanna chip in more
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
