better makes sure you don't smash the sil80 and it stays registered in your name but once you loose your license they freeze registration
Jake if its not your fault other person pays, I'm guessing that's if they don't stop and you don't have a rego number or its a stolen car maybe
  • Replies 14.2k
i swear a whole lot, and even i rolled my eyes at that.
chill pill.
there will undoubtedly be a condition where if you owned the car before the laws came into effect, youll be exempt.
I hope so.
this only happens if u let the court fines get overdue :/
Dont reg the 31, Youll get defected, then just cancel the rego, wasting precious dollars that could be spent on new tyres to fry.
if you have a daily drive then i wont worry about rego'ing the 31 Craig.....
its defected, but i can ermm... get another one to drive on the street..
i dont reckon ill worry about it, ill just do something stupid and get myself in the shit.
i was more so gonna do it for a convenience thing, like wheel aligns, tunes, to and from track etc etc.
but i hear matty likes being my trailer broad minded person so ill leave it at that
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
