  • Replies 14.2k
Nismo Super Coppermix.
ah thats the name.
cheers mate.
will get all fluids done with the timing belt service, might look for clutch prices (ie ebay. lol)
realized Ive got way more than listed previous page, 30row oil cooler, etc etc. awesome
nismo super sports version for $1700ish, NISMO Super Copper Mix Twin Clutch Kit Skyline GTR BCNR33 with RB26DETT engine.
(Sports clutch disk(Copper mix), Sports clutch cover, Light flywheel, Release bearing(Nissan parts), Nismo no: 3000S-RSR35-E
same seller does me discount (jps trading) so could grab this option when needed. ta for the advice. needs to be light as a feather
Rant,
Coming home from a mates place tonight. Coming onto north east rd from Kelly street. Look left look right twice and go. According to the policeman this wasnt enough and i didnt come to a complete stop at the stop sign. $332 fine and 3 points :wub:
could always do what they did on some nissan patrols and thats to add a small power booster to the clutch master cyl making it very light
Rant,
So did you stop? Should be fairly straight forward to fight, especially if you've got a good driving record.
I've heard the argument used in court before about throwing a coin up in the air - the point where it hits the top might not be considered 'stopping', but it is.
Like I told you last night Brendan, Nismo Super Coppermix. You won't get any lighter
CORRECT.
and I can vouch for that 1st hand.
I found the Twin Plate Super Copper Mix had a lighter pedal than the stock 34 GTR clutch......but would bite twice as much
the even funnier thing dion, is how did you find it???? you moving into a jdm supercar purchase..lol
that is some funny stuff, notice the questions about the item too..hahaha
random morning photos to liven things up from a car show in canada
hmm ... wonder what the car was. Nice blue color, possibly aftermarket seats .. hate it when people drape stuff from the rear-view mirror though - or worse (as in that pic) put one of those huggge mirrors and double-sided tape it over the factory one ...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
