Try outlaw speed shop in the city or main north road Nigel!
p.s. Andrew: http://www.skylinesaustralia.com/forums/19...ls-t312968.html
I can not put in words how f**king sick these would look on your 35 man!!!
  • Replies 14.2k
does anyone know where the heck i can get some of these style clamps from today?
they are called "constant tension" , "preformed" or spring band clamps"
from my understanding, they are a factory-only style clamp, and are rarely sold aftermarket.
Tridon make them, as do a few other smaller brands.
need some 23 and 25mm ones TODAY, and have already tried the following:
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
any other suggestions?
http://www.smartbuild.com.au/business-list...es/wingfield/sa
Give them guys a buzz see if they got it.
Ive only ever heard that from you. Been running gates belt for over a year and never noticed any difference in noise.
-D
the only time you should really hear a timing belt is when its on too tight and it'll make a buzzing or humming sound.
Nah mate don't do anything for me .... plus I am a bit in love with my LMGT4 copies :)
Whats it going in? sell me the head cheap so I can build a RB30DET for my drift car :)
I am building up a RB27 - RB25 Block with 26 Crank, Rods with over-sized Pistons, along with having Pon/Pro Cams and porting on the head. So the head isn't for sale, but you are welcome to buy the cam covers or swap for RB26 cam covers plus cash your way.
i suspect thatll be a no go Wayne, Abe searched for ages to find that 25 head!
Indeed I did, found via Facebook, thanks to Dion for pointing it out for me, and I picked it up for a decent price too, $350.
sprints
repco
supercheap
universal fastners
motor traders
pirtek
enzed
CBC
I wouldn't put those on my car, fact is when i replace the hoses they go in the junk box
the custom one on my 3lt is a dayco / gates generic one and its hummed from day dot. Its installed correctly as well (using two tensioners to get the correct spec) so it may be a luck of the draw.
FWIW i wouldnt use a trust / gates painted belt either as they have no stretch on the coating and go tight as the motor warms up.
Std nissan parts at all times, unless there's a reason (ie like dark mentioned with the water pump elongated hole bs)
so abe do i get to take the valve covers to use for carbon fibre molds? you can have them back unscathed , timing covers too???? intake plenum ???
let me know if you want help porting and polishing the head, gasket matching the ports ? done a few in my day..lol
crack test with tracer dye... the head before doing anything to it
and gates belts rock, they used to make them down the road from me in USA, gates batteries(optima as well)
Shit yeah!
    • I do like the look of these things (minus the ugly flat top surface with the text) https://rajabracing.com.au/product/nissan-rb25det-neo-intake/ Retains the OEM bottom runners, for that phat low range. If you want response king, maybe go with the Plazmaman pipe work, here's my old setup from a decade ago
    • Torque will suffer greatly, will try and find dyno difference on r34 with gt30 between stock and plazmaman short runner. like 2000-3000rpm power rdip at least. EDIT Green line is stock manifold, others is plazmaman short runner I also had a rb25 with greddy and q45 TB back in the day and was shit daily driving. Plazmaman top plenum with stock runner and DBW made it so much nicer.
    • Welcome to !
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
