Isn't that normal because the oil breather plumbs into the intake pipe before the rear turbo? I may be wrong.
if thats the case, its not a related issue. should really take pics of my piping before I clean it out... theres too much oil in there to be normal
-D
  • Replies 14.2k
random question
Does anyone work at a place, or know where I could get a 6 way TV splitter tomorrow? like a Hills, or a Clipsal one?
Just spent $73 on a HD set top box to find out my TV in my gaming room isn't connected to the 4 way splitter in the roof... grrrr
/rant.
jaycar
Interesting, you can lease an R35 GTR MY10 Premium
FULLY maintained: $ 3,773.34 per month inc. GST
ill keep that in mind if i ever find an extra $4k a month burning a hole in my pocket.
Dion i need cash for the clutch this weekend, i thought the manufacturer was going to send them through and i pay later but its cash first i can come out to you if its hard for you to get about txt or ring me when you see this 0421932750
Well that was good timing, seeing as I just got up lol
I want these for my rex. I got some saving to do but what do you think?...
http://cgi.ebay.com.au/18-ROTA-GFORCE-WHEE...=item19b7fa3c7c
HELL NO! Get geniune works for that price and your not giving money to a company that blatantly copies other company designs.
Sent you a text before, Im guessing youre at work... Or my last text didnt work lol
Here is there whole cataloge
http://www.rotawheels.com/wheelcatalog.asp
All of them are direct rip offs of Work Emotion series, Work Meisters, Rays/Volk and Advan racing.
And unfortunately they don't "slightly" change them like Drift-Teks did compared to the Bee-R orignials.
As soon as I seen them I was like :( 11R's wtf? lol
:D
You could get genuine works from streeter sent in whatever offset you want for probably $1,600.
:D
The Rota G-Force is a copy of the Advan RS wheel.
11R's are very similar to Advan RS-D which is basically an RS with Dish.
Every company has similar looking wheels, and it depends what you want to run on your car - i.e. $3k worth of rims (genuine advans), $1.6k worth (work) , or $1k(rota). Its a personal choice.
Personally, I bought second hand Gram Lights 57Fs (forged) as they suited the car and application better, BUT i did consider the Rota G-Force at one stage as there is no way I can justify $3k on rims
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
