  • Replies 14.2k
get the sherrifs to break the guys arm? theyre usually pretty obliging :D
-D
id rather sort em out at the counter than having to get the sherrifs to put them in a kung fu grip and boot em out the door.... just makes them angrier for nextr time.
must say its pretty entertaining seeing a massive biker getting taken down, and start screaming like an 8 year old girl with a grazed knee at the hands of a small asian sherrif though
think i found my new hangout when im bored !
How's this.
Brother was driving his n14 pulsar last night. Went through a deep puddle of water and got into his airbox into the engine and blew the motor. One piston is sitting higher then the others and there's a bent conrod. Took the plugs out and u rock the engine and can see water in cylinder 3.
Insurance covers it tho. Damm sr20's
How's this.
Hydrolock, it happens. Luckily his insurance covers him, always wondered about that
That sounds a bit weird to me. The airbox has a hole on the side for intake, and the box is pretty deep - so it should easily be able to drain out or at worst sit at the bottom. The N14 airbox works opposite to skyline one too - with air coming in the bottom and into the engine through the filter at the top, so I would have thought it would be pretty hard to get hydrolock?
Never had any issues in my N14 - it used to run a pod, gone back to the panel. I drove it through a semi-flood in Melbourne a few years ago when was a foot of water going across the highway - handled it perfectly (was using a pod filter back then).
how do i find the correct KNURL diamater for extended nissan wheel studs, M12x1.25 to suit C34 Stagea ?
I bought 20 "Ichiba-brand" 50mm long studs, came with 13.75 knurl - wont fit
Now ordered 20 more with 12.75 knurl, got to wait another 3 weeks till they arrive to see if they fit.
getting to be too expensive to keep "guessing" the size.
Ive measured a used one today from the rear and it seems to be around 12.5mm knurl diameter....... Im hoping its similar to the ones Ive reordered just now 'cause they are 13yrs old & used?
confused :P
confused :P
hey mate: try Jap Import Spares. they sell 10 studs for $40 and we bashed them straight into the drift car
thanks
Ive paid for this second set already, $100 del.
if these dont work will definately try J.I.S. - cheers
oh, I torque them on with a nut rather than bash them on.
got to grab a nut to undo the wheel hub bolt on rear LHS - cant insert new studs due to the parkbrake setup. nut must be 34 or 36mm !!
now I need to see what nissans use 13.75mm knurl - possibly GTR/navara/patrol/"insert Nissan model here"
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
