I swear my RDA slotted rotors are getting, what I can only describe as "hot spots" on them
Cant really see them in the picture, but they are like a dark shadow.
bet you had some grease on your fingers when you installed them ????. pull the pads off , give them a (pads) quick file off and feather the corners to stop chatter and squeal , and spray on some brake cleaner while your there. light sand in a random fashion , reinstall , should reseat within a few blocks. remember you brakes will be low for the first go...lol
pm me if you want a more detailed version..lol
Edited by sapphiregraphics
  • Replies 14.2k
Gee, only 65,000km on the dash .. *cough*
R34 GTR MULTI FUNCTION DISPLAY VSPEC II VER. (WORTH $2500)
weird, I didn't pay near that for the one in my car ... Given all the other items they've quoted costs for, they really seem to have an over-inflated opinion of what adds value to a car.
3.5INCH FRONT/DUMP PIPE (CONNECTED TO A SCREAMER PIPE FOR FASTER TURBO SPOOL)
Aren't screamers illegal?
TBH, the entire car seems like a big sign saying 'defect me' - but eh that's my view. Hope they don't live in SA or VIC or they like bending over ... Lots of threads saying it's impossible to get a RB30/25 conversion through EPA in Vic without spending $3k per test (which you could fail). Ah well ...
im going with the probably just dirt theory. unless youre a secret midnight uber street racer, theres no way youve been going hard enough on your brakes to hotspot the rotors abe.
actually, i should go take a pic of a my ats clutch so you can see what a proper hot spot looks like, lol.
lol, watching a doco on how they build the Corvette Z06:
"The Z06 has cross drilled rotors. These holes help the engine gases escape faster"
lol. i remember hearing that when i watched, i lol'd. other than that, its a good watch.
Edited by scandyflick
heslo! just so u know...
paul said my head was one of the cleanest and un scathed he has ever seen!!
oh and my engine is finished! WOOOP
Fantastic Adrian, like I said, that car and motor was well looked after.
What happend? Oil patch? to fast? someone needed there hair cut down the creek?
f**king LOL!!!!
And none to all of the above, car just understeered off the face of the cliff.
And Dave, yes, he knows
May have had grease, but after installing, I sprayed them with brake cleaner and then washed off with water, I'll have a look tomorrow. I have some copper grease to try and help the brakes from squealing, if the weather is good tomorrow I shall try and do it.
Just a question to the SAU sa execs..
A few weeks ago, Damo said for me to fill out the correct information for a registration form, and all would be sorted. So i emailed my information to sausa's hotmail address, paid the fee's, and have not heard back.
If somebody from the exec team could inform me as to what is going on..that would be awesome.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
