  • Replies 14.2k
watching a doco on future weapons. The USS Dwight J Eisenhower (Aircraft Carrier) was recently overhauled, now has 2 nuclear reactors and can stay at sea for 25 years. The Super Hornets can go for 40% longer, and the weapons are connected to the pilots helmet. They have a heads up display, and it aims the missile wherever they turn their head, and fires with a nod of the head!
*nods head
And aircraft carriers now sport anti UAV/missile laser systems. Cool stuff
And they have a 'heat weapon' getting deployed to iraq at some stage for crowd control - basically a big microwave oven mounted on an APC
-D
-D
or a humvee. theres also a version small enough to loosely be described as squad portable. its called an 'active denial system' or some such.
Looking at new steering wheels.. Ugh.. Like a woman shopping for new shoes..
Always loved the Nardi Classic I got when I bought the car. gonna have to get it retrimmed tho cause the leather is worn to buggery
-D
yup. got a nardi torino on its way for the s14... already talking about swapping it for a personal.
Have you considered re-conditioning it? Leather, being what it is, can quite often be brought back from quite hideous states to near-new.
I recently did this on both of my cars, and the 12 and 17-year old steering wheels now look near-factory.
tried that, they're too far gone unfortunately. needs new leather ;\ wont cost much to get done fortunately
-D
Ive still got the standard Type M steering wheel (same as GTR, but Skyline logo horn button). The leather on that is way gone aswell, will get it re trimmed soon - add it to the ever growing list of things to do haha.
I wish I had some before-after to show you guys how far gone you can still 'fix' a leather steering wheel. My N14 wheel I had written off and been wanting to get re-covered. I figured I was gonna re-condition/re-dye the R34 wheel, and so I'd give the N14 a go for a laugh, and I'm honestly stunned at how well it's come up.
I used the product from PPCCO - http://www.ppcco.com.au/kits6.htm
Damn cheap really, though lots of prep work with various treatments, sanding, filler, etc depending how far it's gone. I figured for $50 it was a cheap chance to have a go and see if it would work rather than forking out $250+ on the two wheels on my cars .. Eh, hey - each to their own. I don't mind trying a bit of DIY - figured I couldn't be in a worse position if I messed it up.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
