  • Replies 14.2k
watching a doco on future weapons. The USS Dwight J Eisenhower (Aircraft Carrier) was recently overhauled, now has 2 nuclear reactors and can stay at sea for 25 years. The Super Hornets can go for 40% longer, and the weapons are connected to the pilots helmet. They have a heads up display, and it aims the missile wherever they turn their head, and fires with a nod of the head!
*nods head
And aircraft carriers now sport anti UAV/missile laser systems. Cool stuff
And they have a 'heat weapon' getting deployed to iraq at some stage for crowd control - basically a big microwave oven mounted on an APC
-D
-D
or a humvee. theres also a version small enough to loosely be described as squad portable. its called an 'active denial system' or some such.
Looking at new steering wheels.. Ugh.. Like a woman shopping for new shoes..
Always loved the Nardi Classic I got when I bought the car. gonna have to get it retrimmed tho cause the leather is worn to buggery
-D
yup. got a nardi torino on its way for the s14... already talking about swapping it for a personal.
Have you considered re-conditioning it? Leather, being what it is, can quite often be brought back from quite hideous states to near-new.
I recently did this on both of my cars, and the 12 and 17-year old steering wheels now look near-factory.
tried that, they're too far gone unfortunately. needs new leather ;\ wont cost much to get done fortunately
-D
Ive still got the standard Type M steering wheel (same as GTR, but Skyline logo horn button). The leather on that is way gone aswell, will get it re trimmed soon - add it to the ever growing list of things to do haha.
I wish I had some before-after to show you guys how far gone you can still 'fix' a leather steering wheel. My N14 wheel I had written off and been wanting to get re-covered. I figured I was gonna re-condition/re-dye the R34 wheel, and so I'd give the N14 a go for a laugh, and I'm honestly stunned at how well it's come up.
I used the product from PPCCO - http://www.ppcco.com.au/kits6.htm
Damn cheap really, though lots of prep work with various treatments, sanding, filler, etc depending how far it's gone. I figured for $50 it was a cheap chance to have a go and see if it would work rather than forking out $250+ on the two wheels on my cars .. Eh, hey - each to their own. I don't mind trying a bit of DIY - figured I couldn't be in a worse position if I messed it up.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
