  • Replies 14.2k
If you are looking for a cheap (but clean) M35 Stagea, or know someone who wants one...check out my sig.
Its a 2003 model, RS4 (AWD, VQ25DET), stock, and in excellent condition.
If you were looking at C34's, at least come and take a look at an M35 - you will be impressed. :/
324mm wilwood brake kit installed, again
20x 50mm extended wheel studs needed (+ spacer) to get rim over calipers
charging a very flat (new) battery then out for skids
well, bed in brakes and new ku36 tyres anyhow
wat size spacers are you gonna run to clear Brendan? Safer option would be to get new rimzzz
yeah I know, 3 sets of rims Ive got didnt fit past the calipers, havent got the funds atm to buy new rims seeing the marriage is finished, house for sale & walking away with $0
decided best for my 2 kids to have my half of the house sale, would rather them have a rooftop for as long as they need
got to write up a legal document to safeguard their half, f**ked if the ex will take everything, shack up with someone else who then rips her for half of MY assets
50mm extended wheel studs all round with 10mm spacers
used to use them, been around mallala last October and used on road for half a year, should be aok with these long studs tho
one day will get rims that clear the calipers, just cant at the moment
f**king GTR's!!! Almost finished, turbos bolted on, all that's left to do is plumbing and dumps then I'll be set! Massive props to Simon for lending a hand; I know you want to see the end of it as much as I!!!
i hear ya brother
what was supposed to be a 1 week job (max) has turned into 3 weeks and ongoing... thanks in no part to a douchebag powdercoater who cant keep a schedule if it bit him in the face
checked in today, gaskets and "issues" sorted, exhaust was to be bolted on just before I left with just intake piping to go.
and then its off to boostworx for a tune. probably wont get the car back till next week.
oh well
-D
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
