  • Replies 14.2k
If you are looking for a cheap (but clean) M35 Stagea, or know someone who wants one...check out my sig.
Its a 2003 model, RS4 (AWD, VQ25DET), stock, and in excellent condition.
If you were looking at C34's, at least come and take a look at an M35 - you will be impressed. :/
324mm wilwood brake kit installed, again
20x 50mm extended wheel studs needed (+ spacer) to get rim over calipers
charging a very flat (new) battery then out for skids
well, bed in brakes and new ku36 tyres anyhow
wat size spacers are you gonna run to clear Brendan? Safer option would be to get new rimzzz
yeah I know, 3 sets of rims Ive got didnt fit past the calipers, havent got the funds atm to buy new rims seeing the marriage is finished, house for sale & walking away with $0
decided best for my 2 kids to have my half of the house sale, would rather them have a rooftop for as long as they need
got to write up a legal document to safeguard their half, f**ked if the ex will take everything, shack up with someone else who then rips her for half of MY assets
50mm extended wheel studs all round with 10mm spacers
used to use them, been around mallala last October and used on road for half a year, should be aok with these long studs tho
one day will get rims that clear the calipers, just cant at the moment
f**king GTR's!!! Almost finished, turbos bolted on, all that's left to do is plumbing and dumps then I'll be set! Massive props to Simon for lending a hand; I know you want to see the end of it as much as I!!!
i hear ya brother
what was supposed to be a 1 week job (max) has turned into 3 weeks and ongoing... thanks in no part to a douchebag powdercoater who cant keep a schedule if it bit him in the face
checked in today, gaskets and "issues" sorted, exhaust was to be bolted on just before I left with just intake piping to go.
and then its off to boostworx for a tune. probably wont get the car back till next week.
oh well
-D
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
