Well I'm off to bed shortly to get up at 4am to make the Red Eye to Sydney before transferring to a Cathay pPlane heading to the land of Hong Kongs .... have fun while I am away ladies .... and yes I will be taking my ban stick with me .... my EeePC sees all :domokun:
  • Replies 14.2k
please. all that eeepc is gonna see is korean porn, we all know that.
oh yeah, plane only has 1 p in it. :)
After getting my tax return, I am either thinking of saving it for my trip to Japan next year, or to put it towards a 52mm Alloy Radiator and a Oil Cooler and Relocation Kit. What would people suggest I do? If I go with the "Upgrades" I am thinking an ISC 52mm Radiator, but not too sure on a good Oil Cooler & Relocation Kit, don't want to spend much more then $350 on the Oil Kit.
abe, youll spend close to half that on a decent oil cooler core by itself. mine was $180 (discounted cause i bought fittings, lines and blocks at the same time) from memory. and oil cooler kits arent something youd wanna cheap out on anyways.
Edited by scandyflick
My tax return is going towards a TIG welder. :domokun:
My oil cooler ended up costing around the $500 but the time i bought all the fittings and hose. The cooler was only $130 and the remote brackets i made on the CNC, so that gives you and indication.
Edited by D_Stirls
On Flea-Bay, you can get kits for about the $350 mark, how good they are, I am not sure, but I am willing to spend a bit more if I am going to gain something out of it, either being Performance, Reliability, or Quality.
yeah, ive seen those ebay kits. and ive seen them being used... and the leaks that followed. dollars doing alright, get luke to track down a grex kit or something.
These 2 things are very important, dont skimp just to save a few dollars. Speak to Todd at Outlaw in the city, he will sort you out with a very good quality kit like this one.
well the 90deg joiners are $50 each, hose is $20 a metre, straight joins are $25 each, core i got from justjap for $120ish, then the plates are around $60 each.
i had a cheap one, snapped fittings and was just shit..
so i paid 300 for the cheap one then another 400-500 for the outlaw one..
DO IT RIGHT DO IT ONCE
ive got a couple 90's, a couple 45's, a couple 45 barbs, and a bunch of straight barbs, and i dont recall paying $50 for any of those by themselves.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
