Well I'm off to bed shortly to get up at 4am to make the Red Eye to Sydney before transferring to a Cathay pPlane heading to the land of Hong Kongs .... have fun while I am away ladies .... and yes I will be taking my ban stick with me .... my EeePC sees all :domokun:
  • Replies 14.2k
please. all that eeepc is gonna see is korean porn, we all know that.
oh yeah, plane only has 1 p in it. :)
After getting my tax return, I am either thinking of saving it for my trip to Japan next year, or to put it towards a 52mm Alloy Radiator and a Oil Cooler and Relocation Kit. What would people suggest I do? If I go with the "Upgrades" I am thinking an ISC 52mm Radiator, but not too sure on a good Oil Cooler & Relocation Kit, don't want to spend much more then $350 on the Oil Kit.
abe, youll spend close to half that on a decent oil cooler core by itself. mine was $180 (discounted cause i bought fittings, lines and blocks at the same time) from memory. and oil cooler kits arent something youd wanna cheap out on anyways.
Edited by scandyflick
My tax return is going towards a TIG welder. :domokun:
My oil cooler ended up costing around the $500 but the time i bought all the fittings and hose. The cooler was only $130 and the remote brackets i made on the CNC, so that gives you and indication.
Edited by D_Stirls
On Flea-Bay, you can get kits for about the $350 mark, how good they are, I am not sure, but I am willing to spend a bit more if I am going to gain something out of it, either being Performance, Reliability, or Quality.
yeah, ive seen those ebay kits. and ive seen them being used... and the leaks that followed. dollars doing alright, get luke to track down a grex kit or something.
These 2 things are very important, dont skimp just to save a few dollars. Speak to Todd at Outlaw in the city, he will sort you out with a very good quality kit like this one.
well the 90deg joiners are $50 each, hose is $20 a metre, straight joins are $25 each, core i got from justjap for $120ish, then the plates are around $60 each.
i had a cheap one, snapped fittings and was just shit..
so i paid 300 for the cheap one then another 400-500 for the outlaw one..
DO IT RIGHT DO IT ONCE
ive got a couple 90's, a couple 45's, a couple 45 barbs, and a bunch of straight barbs, and i dont recall paying $50 for any of those by themselves.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
