  • Replies 14.2k
Haha, I used to get Gag Magic every year as a kid.
Now I normally go for Charlesworth and do the Yellow Brick Road. Oh and dont forget Bertie Beatle!
I remember when Bertie Beetle was cheap as ($1-2?) and I would go in there and buy like 5 lol
SAU discounts? :ermm:
ahh doing the yellow brick road is a hole heap of fun......so when is the royal show???
Royal show is in Sept!
The Gawler show is normally the week before. SA's biggest agricultural show. Hehe
The car im pretty sure is an Integra. I didnt think that was a real question... I thought it was a gay test. Haha
todays test, what kinda car is this ?
one that needs a run around the bedroom, what the hell were you looking at ??? ...lol
im willing to bet my life savings on the fact that your pc has the MOST amount of pornographic
material out of everyone on sau.
you lonely lonely man
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
