  • Replies 14.2k
Haha, I used to get Gag Magic every year as a kid.
Now I normally go for Charlesworth and do the Yellow Brick Road. Oh and dont forget Bertie Beatle!
I remember when Bertie Beetle was cheap as ($1-2?) and I would go in there and buy like 5 lol
SAU discounts? :ermm:
ahh doing the yellow brick road is a hole heap of fun......so when is the royal show???
Royal show is in Sept!
The Gawler show is normally the week before. SA's biggest agricultural show. Hehe
The car im pretty sure is an Integra. I didnt think that was a real question... I thought it was a gay test. Haha
todays test, what kinda car is this ?
one that needs a run around the bedroom, what the hell were you looking at ??? ...lol
im willing to bet my life savings on the fact that your pc has the MOST amount of pornographic
material out of everyone on sau.
you lonely lonely man
