  • Replies 14.2k
Yeh, which Ben built from the ground up with the help of my bro, and other mates. I was there most of the time lending a hand where possible.
Miss those days
the car looked a million times better when ben had it then now that its just a un-cared for drift hack
when he asked me to help a couple times i didnt want to touch it, it was just so perfect lol
pics of my old shitter and what amazing looks like lol VVV
i seem to get a fair bit of bubbling noises outa my car when i switch it off in this weather.
tripple checked the coolent levels after it cooled down and they seem ok, temp gauge seems pretty happy to while driving :) strange cars
Mine actually wants to stall sometimes when I get off the throttle, it only does it sometimes and that's only ever when the AC is on!!!
any one wanna add to my work van fixing fund?
Problem #1... put diesel in it when i picked it up, didnt start, had to wait half hour for it to ''cool down''
Problem #2...smashed the rear window on my gate when i opened the door
Problem #3... scratched the Mc'fek outta the insulation on the side walls while loading in the crane.
Problem #4... dented the refridgeration unit with said engine crane.
Problem #5...leaked about 3 litres of engine oil all over teh inside floor.
wasted 9 bucks with the high pressure hose trying to squirt it out, sorta succeeded.
oh and dont forget the speeding fine i got on the way home, 67 in a 60 me thinks :P
I REALLY HOPE YOU APPRECIATE THAT CHEAP RB20 WITH ''FREE'' DELIVERY ANDREW!!!!!
Off to nissan tomorrow to get prices on the following. Hope i get change from 1500.
• Timing Belt
• Water pump
• NSK timing belt idler bearing
• Tensioner Bearing spring
• 2x Cam seal
• 1x Front crank seal
• NSK timing belt tensioner bearing
• Thermostat
• Fuel Filter
• O2 sensor Part numbers? Front and rear
• 5x Exhaust manifold studs
• Cam cover seal
• Throttle body + Plenum gaskets
• Front diff housing gasket?
• Oil filter block gasket
• Rear crank seal
• Coil pack loom
• Alternator + Power steering belts
• 12x exhaust manifold washers
• 12x exhaust manifold nuts
• 4x turbo to manifold locking tabs
• 1x copper crush washer kit
• 1x oil drain to block gasket
• 2x oil drain gasket.
anyone want to donate to my winch fund?
im sick of pushing busted cars onto my trailer............they're fecking heavy LOL
i'd be happy to help you out at some point, but not sure how much i'd have till the cars back on the raod =\
Timing Belt $80~
• Water pump
2x Cam seal $44~ ea
• Thermostat
• Fuel Filter
• Cam cover seal
• Rear crank seal
• Coil pack loom
Alternator + Power steering belts $30ea~
• 12x exhaust manifold nuts << they are m 1.25 thread , just go to an auto shop and get a pack of tensile ones , way cheaper
hope thats some help , thats some of the stuff i bought for mine :)
haha
should ask more people to break down :)
eh, i'll put off a small spend on the 31 f*kit
appreciate it david, cant have these girls getting the wrong idea
I'm here to help. Your previous statement was going to create extremely high expectations that mere mortal men wouldn't be able to live up to. And that just creates disappointment. Now the ladies expectations have been lowed to the point where all you could possibly do is exceed them.
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
