  • Replies 14.2k
Cara I really disagree with your thinking here. I know you feel guilty but hiding from it is not going to solve it. Go and visit your friend. Tell him you are sorry. He will forgive you. He was there and he knows how quickly it all happened. You both need to talk about it and as Krishy said you both will feel better afterwards. The reason that he was in the car is because he was your friend. Be his friend now and go and see him. It won't be as difficult as you have built it up in your mind.
He will need you help and support for rehab. You will need his help and support to deal with your guilt. Don't abandon each other now when you need each other the most. That is the true test of friendship.
i had an appointment with my pschologist today to talk to him about what happened on saturday...he said what im feeling/thinking is perfectly normal and that i should go see Charlie when i am ready....and not to force myself to go. I have sms'd him to make sure he is alright but that is as far as i can do at the moment i am still having trouble with realising that it all happened on saturday, im having nightmare after nightmare aswell which isnt helping.
Is it possible your feeling guilty because your weren't paying attention and singing songs driving and being silly with your mate when this unfortunate accident happened
“Do not judge, or you too will be judged. For in the same way you judge others, you will be judged and with the measure you use, it will be measured to you (Matthew 7:12).”
you were stupid enough to assume that i was f**** around in the car and not paying attention to the road
and the way u said it was not asking a question, but was assuming that is what i was doing.
anyway im not wasting anymore energy on this, or you for that matter.
possible
Main Entry: pos·si·ble
Pronunciation: \ˈpä-sə-bəl\
Function: adjective
Etymology: Middle English, from Anglo-French, from Latin possibilis, from posse to be able, from potis, pote able + esse to be — more at potent, is
Date: 14th century
1 a : being within the limits of ability, capacity, or realization <a possible but difficult task> b : being what may be conceived, be done, or occur according to nature, custom, or manners <the best possible care> <the worst possible circumstance>
2 a : being something that may or may not occur <a possible surprise visit> b : being something that may or may not be true or actual <possible explanation>
3 : having an indicated potential <a possible housing site>
need i hold your hand further through the english language like half of SAU that doesnt read or comprehend /caring
The way you phrased your dialogue only questions the possibility of her guilt. It is continued with a statement 'because you xxx' which implies fact when not concluded with a question mark.
English grammar fail.
-D
i wouldn't conclude that sentence with a question mark as its not a 'why' 'who' 'what' yadda yadda
You started the dialogue with an open question, that being the word "Is" which implies a question, and hence would end the sentence with a question mark unless a preposition or caveat is mentioned, which you clearly did.
keep miss reading i don't care
Grammar fail #2
-D
Guest
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
    • Makes sense. For actuators, if the pressure itself isn't adjustable, that would mean I'd need to think about 2 different actuators with 2 different pressures on paper in order for them to work at the same time if the turbos behave differently. So measure the difference in psi needed to move both, and then get an actuator to match that difference. Assuming I cant get rid of it by adjusting the arms.  You're exactly right, never happens in gear 1 or 2. I can occasionally get it in gear 3 if going uphill but its very small. Only ever in 4 and 5. Seems kind of backwards that one of the points of VCAM is faster spool but if it introduces shuffle then it actually slows spool down.
