its doable, im listening
As am I, I am waiting for the answer to this
...What if I can source a RB26 Head, and swap it for 1 of your RB25 Heads?...or how easy is it for a RB26 Head to go on a RB25 Block?
EDIT: Thought I could source a RB26 head, but I can't unless I do a bit more searching, but how easy/hard is it to bolt a RB26 Head on?
...Now you can wait till later tomorrow, as I am going to bed, damn work tomorrow :blink: , but money is money, and I need it.
But I shall see what I can find.
  • Replies 14.2k
That looks killer Adrian! Did you put in anything extra or special for running E85, or is it all normal gear?
nothing special just replaced any exposed rubber when I first converted, been nearly 3 years without any issues, 99.9 cents a litre is a bonus, and smells much nicer than unleaded!
You still bringing it in by the barrel?
Guest
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
