URGENT!!!
Anyone got S2 R33 rear brake pads lying around? Even a used set for the 2 pot calipers ... even one side ... don't care. Need asap.
Started brake upgrade on the Stagea and I'm short a set of pads I thought I had. Stag is my daily, so I need her finished asap ... even with a temp set of pads.
PM me or sms 0449 928 227.
Ruby
  • Replies 14.2k
I had my F**K EXAMS afterparty in town last night. I had many a beverage lol. Woke up in a house at Henley Beach, got home at 2pm today. Basically the first half of today (and some of last night) was the same storyline as Dude Wheres My Car. Now my butt hurts (I had to push my sphincter back in when I woke up this morning), and my fingers smell like peanut butter - WTF??!!
^^^ Fixed for completeness :P
Hey Andrew, you left your top and wheel brace thingy behind today. Don't worry mate, I got them for you! It'll cost you a turbo-manifold gasket ;)
Oh, and I left my 30m ext cord at the yard too :P
Ah cool mate - give me a ring tomorrow and you can pop over and pick up your gasket .... probably won't be home til later in the arvo though - if you want I can leave the gasket in my letterbox?
Bugger - I was going to yell out to you not to forget your cord, but figured you would have to drive PAST it on your way out, so would see it. You might be lucky and it still be there tomorrow.
Thats cool. I can pick it up from your letterbox tomorrow. I'll be home most of the day, but will be shooting out about lunchtime.
Yeah, I was in a bit of a rush to make sure I got Tracy to work on time, that I left in a hurry. :)
Drove past earlier and had a look from the Cavan Road end of the yard, but its obviously been nicked or taken in upon lockup. I'll chase it up first thing tomorrow.
URGENT!!!
Ruby
Ruby i have some brake pads for a R33.....pretty sure the S1 and S2's are the same mate.....they are used but still got a heap of meat left on them mate.....they are lucas pads....you have my number contact me on that mate....btw pm has been sent as well :)
if someone has a stolen i phone and its jail broken can it be tracked?
my brother had his stolen and he jailbroke it...
cheers
Yes, unless you disabled apples backdoor with SBSettings app from Cydia by turning the kill switch off.
URGENT!!!
Ruby
All sorted out now thanks. Thanks to those who offered :)
I can get you some standard struts and I will have wheels with good tread but they're on the car and have nothing else to put on it Kye.
Cheers man. I'll let you know shortly if the ones that I've lined up fall through.
Thanks
One sunny day in January, 2011 an old man approached the Canberra Lodge where he'd been sitting on a park bench. He spoke to Commonwealth security standing guard and said, "I would like to go in and meet with the Prime Minister Kevin Rudd."
The Guard looked at the man and said, "Sir, Mr. Rudd is no longer Prime Minister and no longer resides here."
The old man said, "Okay", and walked away.
The following day, the same man approached the Lodge "I would like to go in and meet with the Prime Minister Kevin Rudd."
The Guard again told the man, "Sir, as I said yesterday, Mr. Kevin Rudd is no longer the Prime Minister and no longer resides here."
The man thanked him and, again, just walked away.
The third day, the same man approached the Lodge and spoke to the very same Guard saying, "I would like to go in and meet with Prime Minister Kevin Rudd"
The Guard, understandably agitated at this point, looked at the man and said, "Sir, this is the third day in a row you have been here asking to speak to Mr. Rudd I’ve told you already that Mr. Rudd is no longer Prime Minister and no longer resides here. Don't you understand?"
The old man looked at the Guard and said, "Oh, I understand. I just love hearing you say it."
The Guard snapped to attention, saluted, and said, "See you tomorrow, Sir."
:( f**king fantastic!
HAHAHAHA :(
Guest
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
