to tierd to remember the plates - but saw a black line at silverwater road at Dundas..
and saw a redish line at Baulkham Hills ... on windsor road... and glimpsed a silver/grey line parked near cross st in baulkham hills..
I was at the north shore and St Leaonards allll day and didnt see one then see 3 when I get home.. heh
spotted a blue R33 of some kind on Maxwell St - South Penrith around the 4:00pm - 5:00pm time, it looked like it had the limited edition 40th An. colour.
Didnt get a good look as i saw it at the last minute, didnt have an aftermarket exhaust so i didnt hear it.
Looked very nice, i also saw heaps of soarers.
Saw A nice Silver R32 GTR.
Just after the Galston turn off towards glenorie...
i was in a white R32gtr..
u from that area?
and also a White R33 GTST i think it was
i saw pull in on the servo...while i was refueling...
this was a week ago
]']Saw A nice Silver R32 GTR.
u from that area?
this was a week ago
The white R33 might have been me.
The Shell servo near the Maccas and KFC in Dural? what time?
wil..
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
