Spotted several skylines last night around the northern beaches including one complete idiot P plater in a white R33 GTR with no rear wing at Dee Why beach who took off up the road and around a corner nearly taking out a parked car and hitting ludacris speeds up a residential street.
Spotted an R32 gtst JNR-032 and VL---- cruising together at Manly. Spotted a black 32 on Old Northern Rd going towards castle hill as I was turning onto Gilbert Rd. I think ther were three guys in that car and they saw me first, beeped and waived. I only had time for a nod. That was on Friday...
heh... It was me.... :wassup:
Spotted a nice white 34 coupe (VY-19??) on James Ruse Drive yesterday arvo...nice wheels :( Anyone on here? I gave a quick nod when I passed you in the traffic, but I doubt you would have seen it as our tints are both pretty dark (I know I couldn't see you).
Also spotted a grey 34 4-door with Raine & Horne Chinatown stickers all over the rear end - seen you a few times lately on Victoria Road, Rydalmere and City West Link, Haberfield.
spotted the same 4 door at carlingford yesterday
spotted a white 33 on beecroft rd at about 10:15am.. i was going straight onto epping rd, s/he was turning right onto blaxland... it had a nismo sticker on the front... thought it might have been you sam! (sawatika(sp?)) I only saw the car in the rearview mirror, so didn't get to chat or wave or anything :(
ok spotted a black R32 GTR just off penno rd on marsden rd pulled over by hwy patrol
IN A SCHOOL ZONE
the car looked mean, had some hot wheels, aftermarket cooler, carbon bonnet, bride seats, number plate mounted on side.
and a seriously worried driver.
good luck with that!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
