spotted a killer R32 GTR white with big autostyle sticker in Rockdale..forgot the number plate ..was new ones.. but the car is pulling 450Kw@wheels ...OMG
Did it have a sticker saying 450kw@wheels?:P
I spotted u(ATD 37R) few times on pacific highway but u r early today... bcos i normaly see u on the way back to chatswood.. after drop off my gf at Mater Hospital at Wollstncraft.
did I wave back? I remember I was trying but need to shift gear :wavey:
I like ur muffler sound.. what r they?? once u were boosting out..... and it sounds great :wassup:
Ah yeah I remember now! Your the guy that NEVER waves!!! lol...jk
but nah...you didn't wave! No excuses next time!
Spotted - gunmetal grey 33 turning into Miller St from Pac HWY in N'th Syd at 6pm on Friday. Got a nod. I want your rims!
First your side mounted number plates
Second, Proconcept sticker
Third, the wheels
and lastly.... taking up two lanes and getting beeped by a truck behind... ;) typical korean taxi drivers style :D :D :D :D
1) are you korean ?
2) have I met you ?
3) do you go to josh as well ?
4) It wasnt my fault.....SOMEONE was in my passenger seat and couldnt make up their mind which direction they wanted me to go !!!
I hate when people hog lanes like that......so I didnt do it on purpose !! :)
pm sent... was getting too much personal chit chat to post up here...
actually posting this msg is too personal too... gotta think of some skylines just to get back to topic... :)
hmm.. think...
GTR000, wine r32 gtr on epping road yesterday...
I have been driving to Pennant Hills from Campbelltown every day for a week, flashing and waving to every skyline that goes past, and still wasnt spotted :cheers:
I'm so dissapointed that I'm going to buy a weekly train ticket tomorrow and keep the line in the garage so I'm not wasting fuel
hrumph
hrumph
are you sure your driving a skyline?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
