i think i saw u sawakita :rofl:
on epping road (actually i think it turned into beecroft rd) going in the opposite direction toward beecroft. this was next to epping station after the tight bend.. would of been around 11.30
didnt see the number plates, but it was a hot looking white r33 gtst s2 like the one in ur sig..
Hot looking white R33 gtst s2... hmmmmm... that MUST be me :wassup: JK
could be me bcos I live in Beecroft:D I've seen few skylines on beecroft rd.
but I'm just too lazy to come typing :zzz:
spotted black r33 gtr on castle hill rd castle hill bound @ 3.20pm & white 33 s2 @3.21pm white 33 s1 @3.35pm castle hill rd thompsons corner bound. also black 32 on anzac parade randwick bound who beeped as i was about 2 jump the fence @ 11.45pm & gun metal 33 on anzac parade city bound 11.50pm
just thought id mention i didnt spot a white R32 GTR on marsden rd this afternoon
and it wasnt danny.
and ur headlights were on 4 some reason
also i did spot a black r32 gtst on penno rd waiting to turn onto carlingford rd
ahahaha that was me :kick:
i just got my rims sprayed black and N1 skirts
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
