was it a p-plater? with one of their back round lights not working?! i spotted him on castle hill rd at that intersection on saturday.. i tried to tell him, but the girl in the passenger seat had her window up!
also spotted RUFGTR on newlone rd on sunday at midday :)
also spotted RUFGTR on newlone rd on sunday at midday :D
I think it was a p plater. Was parked though. Had rims and looked lowered.
Saw a silver S2 GTST on Pennant Hills Road around 6.45AM this morning. Exchanged thumbs ups :thumbup:
Also saw a gold R33 with no spoiler turning onto North Rocks Road from Pennant Hills Road at approx 3:20PM
Spotted AIVIOL heading East on GWH at Blaxland yesterday, chatted to him through the 40 zone! Must say one of the nicest 4 door 32s I have seen.
Oh, and spotted Bonkers the other day... he was parked in his garage! :D :hehe:
"Spotted AIVIOL heading East on GWH at Blaxland yesterday, chatted to him through the 40 zone! Must say one of the nicest 4 door 32s I have seen."
Thanks for the nice comments Majanal !!!
Obviously i spotted Majanal in his 33 yesterday:)
