DHC - Castle Towers piazza carpark last night.
was with my mates when i saw it, i swear.. that car just gets hotter and hotter every time i see it.
Yeah i seen your car parked at York street on Fri night at 8:00 pm and i lloked around to see if you were there..you took a parking ticket till 10:00 pm..
Seen ECL too on Walker street Nth sydney in his white 34 at 12:30 pm
hahaha i know eh...
maybe next time you'll spot me! haha..yeah my mates and i were goin off..such a nice car.  :(  :thumbsup:  :thumbsup:
haha if yours was the blue 32 with plates NUT-532 then yeah I spotted ya...
just didnt know it was someone from the forums... :D
NICE colour......its not stock eh ?
and R34NOS...yeah that was me....but it would have been thursday night ;)
just didnt know it was someone from the forums... :(
and R34NOS...yeah that was me....but it would have been thursday night :thumbsup:
ahaha nah unfortunately not..
but i saw that one too, forgot the number plates. very nice though.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
